whoa there. mids mounted on dynamat?-Signal voltage is 4V from KDC-HD942U-Box is a little large for sure yes...I want to rebuild one around 1.5 cuft sealed into the spare tire well.....this will be a big project.
-Tweeter atten. is at -3db as of now per. I spent the last 2 hrs wrapping the panels the tweeters were connected to in matte black vinyl to hide the original mounting holes, then remounted them ON axis, with -3db. Midrange was never the problem, guitars and spoken word are VERY strong. Midbass I mean 80-160hz.
-I know the amp *****, thus why I explained the very poor 72db s/n
- Mids are in stock location on doors, mounted on a 10"x10" sheet of Dynamat xtreme. The doors have holes for sure, the biggest being around a foot by ten inches, but that is around a foot from the speaker mounting (right in the center of the door).
Efficiency plays a role in that comparison. By design most car audio component drivers are not very efficient. Also in the house you are listening to your sources on axis. Then finally you have ambient noise floors making a difference. You largely perceive the home stereo to be louder because it has less ambient noise to overcome unlike the automotive environment. All these play a factor in your perception that 110watts in home is louder than in car.Besides sensitivity, is there anything else that effects volume based on input power? How is it possible that 150w a side is not loud enough for me in a CAR setting, when 110w a side in my home theatre is deafening?
You don't NEED horns. That is just one solution. You can go to a 3-way front stage. Of course the most cost effective and obvious solution is to try as has been suggested and really work at treating your doors and a set of baffles for the drivers you have and see how that goes first. If that doesn't satisfy you then obviously you will need to rework your front stage in some fashion to get what you are looking for. Could be a number of ways to attack the issue.What the ****? I need horns to get loud? I really don't want to damage my hearing and require a shitload of tuning. Doesn't anyone listen to their music loud, and have it crystal clear? I think you are right though about running seperate amps for the tweets and the mids/bass. What do you use for crossovers though since no amps have 5000hz x's for tweets? Passive?
