i need a amp fixed
  • 4
DjSpecialK17
i have a soundstream xxx 10,000 i was playing it and i look back and it was poring out smoke, any way its not in protect i did not open it up yet but i need some one to fix it and i know wat i did not do rite i didnt wanna wait for a new alt. so i had some voltage drop and im an *******.
but anyone know where i can send it to be fixed or if its worth fixing???
id say you hit a voltage tooo low and burnt up some fets. cause i had the same problem (same amp), my voltage dropped to low and burnt some fets and resistors, the amp still played was not in protect. should be an easy fix. good luck man.
980
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
DjSpecialK17
DjSpecialK17
Shirley, NY
jmkanek
Decebal
    Jun 10, 2024
