I need a port
  • 2
Originally posted by pheonix Box eternal dimensions are
IS that external //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
how thick is the wood ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
wood thickness is 3/4 inch so...
dimensions are, oh wait
actually i listed them wrong anyway...
internal dimensions are 16W x 31.5D x 11.75H those are INTERNAL so internal volume before any displacements is 5922 cubic inches
I was thinking maybe around 30 sq inches per sub? 8X4 for surface?
Thanks for further help
pheonix
Let's see for rap I would tune it around 32hz. And using your given dimensions. I come up with 8" x 4" and 19.75" long That will give you a 32hz tuning and 32"^2 of port area. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
would you have done anything different than that or do you think this should work out ok even with that long of port?
Thanks for the help
I'm guessing this is gonna boom pretty good
pheonix
Nah man. Everything sounds good to me. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Yeah it should really boom. What kind of power you going to be pushing to them? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by pheonix around 1200 watts from a cadence A7..
thanks for the help
pheonix
D@mn dude. I would definately say you will have some bump //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif No problem my man. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
I am considering upgrading the sound system in my 2013 Ford F150. I have identified three potential head units: the Sony XAV-9500ES, the Pioneer...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
454
pheonix
pheonix
Wisconsin
ramos
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
