I need a relay or something
zogthegreat
Hi everyone!
I have a bike rack on my 2011 Ford Taurus that I want to install a light that activates when I step on the brakes. Due to the way Ford setup the lights on the Taurus, I can't just tap into the brake lights in the rear. I did manage to tap into the brake light that is in the back window, but due to voltage drop, I'm only getting 6v at the end of the wire. Since I already have a 12v hot wire running to my trailer wiring, what I would like to do is have the wire that comes from the rear window brake light run to some kind of relay or switch to the 12v hot and then from the 12v hot to the bike rack.
Does anyone have any suggestions?
Thanks!
zog
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
462
354
zogthegreat
zogthegreat
Montreal, QC
adulbrich
    May 16, 2024
    May 16, 2024
