I need a relay or something
  • 3
zogthegreat
Hi everyone!
I have a bike rack on my 2011 Ford Taurus that I want to install a light that activates when I step on the brakes. Due to the way Ford setup the lights on the Taurus, I can't just tap into the brake lights in the rear. I did manage to tap into the brake light that is in the back window, but due to voltage drop, I'm only getting 6v at the end of the wire. Since I already have a 12v hot wire running to my trailer wiring, what I would like to do is have the wire that comes from the rear window brake light run to some kind of relay or switch to the 12v hot and then from the 12v hot to the bike rack.
Does anyone have any suggestions?
Thanks!
zog
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
198
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
228
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
558
11
502
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
zogthegreat
zogthegreat
Montreal, QC
adulbrich
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
