I need a wiring diagram for my 1994 nissan pathfinder pleasee
  • 2
DIRECTWIRE™ WIRING INFORMATION - NISSAN / PATHFINDER / 1994 / Remote Start
[PRINT THIS PAGE]
12volts white/black + ignition harness
Starter black/yellow + ignition harness
Second Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Accessory black/blue + ignition harness
Power Lock black/yellow - driver kick panel
Power Unlock black/red - driver kick panel
Parking Lights+ pink/blue steering column
Door Trigger red/black - left A pillar
Trunk/Hatch Pin common with doors
Trunk/Hatch Release lt. green/red + at release switch
Tachometer white AC lrg. conn. by dr. kick
Brake Wire green/yellow + at brake pedal switch
Parking Brake
Horn Trigger lt. green/black - steering column
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
472
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
danteBirosel
danteBirosel
San Diego, CA
6spdcoupe
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
