wiring battery, starter, and altenator
  • 1
Johnston_2007
hello i think i have a problem on my truck. i think that the guy i bought it from last year has the wires hooked up wrong and i need to know if anyone knows how to wire the battery, starter and the altenator together. right now i have a possitive wire running from my battery down to the starter and then from the starter to the altanator. this this correct? and the truck is an 89 gmc sierra 1500 4x4. or should i have a wire running from the battery to the starter and then another one from the battery to the altenator. thanxs alot guys
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
As I sit and Stare at this Pic. I keep thinking to myself of how easy it is just to drill a hole in that + battery connection as it looks as...
4
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
99
Johnston_2007
Johnston_2007
Bonne Terre, MO
Johnston_2007
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
