i need alot of power!
DAATH
atlanta
not white power... amp power! i'm gonna be running dual mlk165 drivers per door on a 2ohm load, with id ultra horns. gonna run 2 amps seperate for the mlk165's and the horns. i would like to get around 600 watts per door. i was looking at the hertz H2, but larry @ elettromedia said the amps are huge and not very sq friendly. anybody know of a high powered, balls to the wall sql amp that can meet my goals?
600 per door? Wow!
I give my mids 300 each from one of those new JL HD 600/4 amps (bridged). I also use another 600/4 to run my front tweets and rear coaxials.
The sound quality is amazing and it's darn loud.
good god why would you need that much power for your regular speakers?
I had 100 watts going to my components and they could get louder than I ever cared to listen to them...
if it was 4 ohms i'd suggust the Q700.2 but since 2 i'd suggest the 1200.1 one per side //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
1200.1 per side? that's insane!!!!!
It's almost like you can tell the equipment isn't straining to get loud. You don't have to crank the gain knob or volume knob and therefore you eliminate clipping and distortion. But I'll admit, 100 watts per side is normally plenty. I figured I was insane with the amount of power I'm feeding mine, but 600w per door? And aren't horns really efficient/loud anyway? I have no experience with horns, so correct me if I'm wrong about that.
Hearing loss in 3...2...1...
the horns will see no more than 100 watts
he gotta balance out the power he's got going to his horns. them ultras can get really loud. i have a ID Q700.2 going to my horns gained all the way down, a Q700.2 ran stereo to 2 6.5s per door giving me 325 watts per 2 x65mids then a 1200.1 for my 2 IDQs. now when the x8s come out i'll be running one 700.2 bridged 4 ohms 650 watts per 8.
don't hold your breath on that XS8
crystal cad600.2T is a class t amp so it has class d circuitry and effeciency while having a\b sound quality and it is underrated and i have one like new in box mint
150X2 4ohm
300X2 2ohm
600X2 1ohm
1200X1 2ohm
it looks just like a ed nine.1 but silver
and it has low pass, high pass, fullrange crossover settings
i want 230 shipped plus any fees
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
349
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
712
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
462
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
512
DAATH
DAATH
atlanta
DAATH
