Ignition wire for Radio is dead?
  • 2
sacarap
Hey everyone,
I am new here but could really use someone's help. I have a 1994 MItsubishi Galant. I am installing a Sony xplod cd player and have come across a problem. I had everything working but when I was mounting the player I had a loose wire (ignition wire) and it got grounded out with the car on. Now my cd player will not turn on with the car because that wire does not have any power coming from it. I know the radio is not blown because if i hook up the ignition wire strait to the constant 12+v then it will turn on.
So my question here is: Would there be another fuse other then in the main fuse box, for that ignition wire? I put the volt meter on it and its definitly dead. I checked in the cars fuse box for a fuse, but it doesn't have one there. I am guessing that there is another fuse somewhere, but I'm not sure where!!
Any feedback would be greatly appreciated !!!
Thank you !
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
707
I did yeah. The OEM Harness was frustrating because the pinouts for the aftermarkets had the wrong layout. I have it correct. I'm measuring low...
5
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
8
Thanks for the clarification. Fuse boxes generally have some blank spots you can tap into.
6
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
333
sacarap
sacarap
skitzo
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
