Installing new Alpine CDM-7871 with older 5952 CD changer
  • 1
88Saleen
I have an older M-Bus Alpine 5952 cd changer that has an 8 pin din plug and 2 RCA plugs for the left & right channel. My new CDM-7871 Alpine head unit has the M-Bus 8 pin din plug but no RCA plugs for the left & right channel. Apparently, the newer M-Bus design incorporates the left & right channel into the din plug. I need an adapter to convert my din and RCA plugs into one 8 pin din plug. Anyone know where I can get one?
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
88Saleen
88Saleen
88Saleen
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
