Is 1/2 mdf good enough for Sundown U?
  • 3
CarAudio.com Regular
163
49
Ohio
Probably already know the answer is no, but my friend wanted me to build a box for a Sundown U 12. Gonna have an sfb-2k on it so it's gonna be taking a beating. Meant to buy 3/4 but I had a long day at work and barely made it to Lowe's before they closed and accidentally pulled the 1/2 off the shelf instead of 3/4 and had them cut it in fourths to fit in my jeep.
Maybe just maaaaaybe... If I did a double baffle and did some extensive bracing would it work? Not tryna have the box flex and snap while he's jamming. Or should I cut my losses and go back and get the 3/4? The 1/2 was only like 50 bucks for a sheet. Just don't want to have a bunch of mdf laying around in my already crowded garage.
Double the whole box, if you can. That’s gonna be hard to do right, though.
Yea and I've only ever build a couple boxes so I'd say just go back and get the 3/4? I'll just use the 1/2 to make some small 8 inch boxes and sell them on Facebook. I just needed the opinion of someone who knows what they're talking about
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
Ohio
hispls
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
