Is it possible to put a 89 chevy model motor in a 2000 are newer model?
sthib
la
i have a 89 chevy single cab that has a new trans and rebuilt motor i want to find a 2000 are newer extended cab chevy that needs a new motor are trans and put it in that one rather than buying a whole new truck.
is this possible.
if the mounts line up yes. if not still yes after a lot of custom work. Also i hope you don't live in a state that dose testing on vehicles if you do your screwed
Well, generally small block chevys dont change much, so depending on the motor thats in it, yes you can swap it. Is the 89 model motor fuel injected or carburated? I can guarantee the 2000 and up models are all fuel injected. if its a regular chevy small block you can just take your intake off it and use the injection intake from the newer truck if the manifolds/heads match up. Not much to a chevy.
Only one thing I have a problem with doing it , is the electrical side of it. What sensors and other parts will be different. Im sure alot will be .
yes it is pssible but theres only one catch. The motor you have in your 89 is im guessing a 350 tbi(throttle body injected) and it has a carbrator, and the motor that would be in the newer trucks from 95 and up are called vortecs(fuel injected) and they do NOT have a carburator. So what you would haved to do it buy brand new motor mounts, computer, wiring harness, hoses, radiator, etc. From my experience your best bet would be to just keep the motor and trans in your 89 keep that or sell that truck, and buy your 95 and up chevy and just go to your local junk yard and buy a vortec and trans from there. There vortec trans and engines are BOLT ON AND PLUG IN AND GO!!!!
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
676
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
8
945
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
sthib
sthib
la
chevy98guy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
