is it worth fixing
  • Thread starter <Orion>
  • Start date
  • Replies 3
  • Views 2K
  • 1
have you checked your remote lead? Ive had brand spankin new fuses be bad, and no it wasnt blown, it actually caused a 9 volt drop across it...that was a funky problem. Do you have for sure 12 volts to the amp? If the car is running it will be 14.4 volts. I suppose if you dont have a Volt Ohm meter it is alittle tuff to see that. Have you got a good ground? Checked all the fuses??? exhaust all posabilites.
yes the fuses and everything work be cause when we hooked up another amp it worked fine so how mch do u think it will cost to fixk or is it even worth it
one of my friends had a problem like this and it was some type of internal switch it costed him about thirty dollars to get it fixed
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
5
668
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
11
Guest
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
