is it worth fixing
  • Thread starter <Orion>
  • Start date
  • Replies 3
  • Views 2K
  • 1
have you checked your remote lead? Ive had brand spankin new fuses be bad, and no it wasnt blown, it actually caused a 9 volt drop across it...that was a funky problem. Do you have for sure 12 volts to the amp? If the car is running it will be 14.4 volts. I suppose if you dont have a Volt Ohm meter it is alittle tuff to see that. Have you got a good ground? Checked all the fuses??? exhaust all posabilites.
yes the fuses and everything work be cause when we hooked up another amp it worked fine so how mch do u think it will cost to fixk or is it even worth it
one of my friends had a problem like this and it was some type of internal switch it costed him about thirty dollars to get it fixed
They are solid amps. I've had it since 2012 and it's worked great. Getting a truck soon and looking to get a smaller amp with more power. Smart...
233
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
815
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
Guest
