whats the best amp
emojerk
im new to the car audio world. i have two crossfire 12's and the nominal power handling is 150 watts each, the maximum powe handling is 250 watts each, and the dynamic power handling is 400 watts each. which wattage to i need to pay attention to when finding the best amp for my subs?
LIGHNING AUDIO S2.500 would be the best amp to push any thing. I've pushed 2 jbl 12's, two solo baric 12's rounds, two polk ex series 2 12's, and now two kisker vrcomp 10's. the life of my amp one hell of an amp
LIGHNING AUDIO S2.500 would be the best amp to push any thing. I've pushed 2 jbl 12's, two solo baric 12's rounds, two polk ex series 2 12's, and now two kisker vrcomp 10's. the life of my amp one hell of an amp. 800dynamic watts 150 watts per chan 2 chan
Originally posted by emojerk:im new to the car audio world. i have two crossfire 12's and the nominal power handling is 150 watts each, the maximum powe handling is 250 watts each, and the dynamic power handling is 400 watts each. which wattage to i need to pay attention to when finding the best amp for my subs?
Well to answer your question, you need to pay attention to RMS not really peak. You want to give the sub the rms rating, maybe a LITTLE under or over.
To continue
It is possible to over power the sub a little more in a sealed box. But if you port the box, you really should stick to the rms number.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
emojerk
emojerk
goose creek, sc
big_jeffrey
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
