Is there a way to control the "tone" of an aftermarket sub through factory deck?
  • 3
svt440
Hey guys! I am thinking about installing a sub and amp in a 2008 Pontiac G6 that does not have the Monsoon System. This is a very basic setup. Factory head unit, two door tweeters and 6.5's, and two rear 6x9's. What I would really like to do is have the sub controlled by the "tone" settings in the factory cd player. (these are the high mid and low settings). When I turn up the low on the head unit, the bass hits harder, and when I turn the low's down, the bass doesn't hit as hard. Has anyone found a way to make this work? Also, how would the master volume on the factory head unit control the volume of the sub? Thanks!
They work now with my factory speakers, but when I add a sub, I am wanting to be able to (for example) turn up the low on my factory head unit which will turn up the sub low's. Some people say you can't control the tone of an aftermarket sub through a factory head unit. I think through some cross over's that this may be possible.
I do not remember that HU at all. I do remember that Crime Stopper had features like those but not controlling the HU? Clifford alarm system would...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
4
svt440
svt440
United States
svt440
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
