JL or Kicker?
I like the 300/4. It only shut off on me once. Not trying to scare you or anything, but the day it shut off on me, it was super hot outside, maybe around 95 or 100 degrees. I had the amp playing for a good 2 hours straight. Other then that I never had any problems with the 300/4. I haven't had any experience with the kicker amps.
Oops, my bad. It was on the first couple pages, so I just assumed it was recent. Not often someone lets a FS thread go on that long without making a new one.
900
Concep29
Concep29
Lake Havasu
WhoSayWho?
