keep blowing w3s
  • Thread starter <infamous>
  • Start date
  • Replies 2
  • Views 2K
  • 1
<infamous>
Guest
need help i keep blowing the secound speaker in my series setup and i cant figure out why. they are jl audio w3 d4s hooked up to a rockfordfosgate 500.2. every thing is hooked up right. ohms are at 4.which is right. i know im not putting to much power in to it
if you have 2 D4's in series that isnt 4 ohms, it is 16 ohms. wire it in series-parallel (coilsm in series, subs in parallel) for 4 ohms. and no, that amp shouldnt blow them, i know someone puttin over 300 to one and its fine. are you breaking it in before you pound it hard? and is the box the wrong size? are they sealed, if so you divided the chambers right?
You can pull that amplifier and take to an Audio shop and see if they will test it. Most shops charge very little and some will not even charge...
8
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
12
The best thing you can do is make a solid plan. This way you won't be spending money twice and having to keep going back in add or replace parts.
27
3K
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
287
Guest
zane
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
