Kenwood Excelon KAC-X501F & KAC-X401M $170 shipped for the PAIR!!!
  • 2
NSTALN
Dismember
Pair of old-school Kenwood SQ powerhouse amps.
KAC-x501F 4 channel and matching KAC-X401M mono amp
$90 EACH SHIPPED OR $170 FOR THE PAIR
Don't let the specs fool you...people who have used/installed this series of amps knows they are very under-rated and SQ oriented.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kacx501f.pdf
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KACX401M.pdf
KAC-X501F: Good condition considering it's age. Works 100% with the exception of:
-Front channels very rarely develop static...this is from the crossover selector switch, switch it off-then back on and the issue goes away. This has happened to me 3 times in over 10 years of faithful service from these amps. All three times the amp was mounted right next to a 15inch sub...so I may have been rattling it loose.
KAC-X401M: Good condition considering it's age. Works 100% with the exception of:
-Fan cover mechanical door stays in the 'OPEN' position. This does not impead any functions of the amp or it's controls because the "OPEN' position exposes both the cooling fan and the sound controls.
-The sub-sonic frequency selector switch does work but it requires a pick tool (right angle seems to work best) to move the switch. The switches on these models are very small and are recessed, the lil plastic part broke off the switch and like I stated just needs a pick tool to adjust.
I can't say enough about these amps. I hate to see them go...but times, vehicles, and systems change. For those who can appreciate these amps, this is a hell-ova-deal. For those who can't get past that name 'Kenwood' on the front, these aren't for you.
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
Aslo, if you use your head unit for phone calls, read through the manual so you can set the speakers to use with bluetooth calling to front. Trust...
6
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
482
NSTALN
Dismember
NSTALN
Manchester, NH
NSTALN
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
