Kenwood eXcelon KFC6903 6X9 VS Kicker KSS269 6X9
Here is a question I'd like to ask. It sounds as if I'm going to bother with replacing all 6 speakers in the front AND adding a 10 inch sub under the rear seat I'm going to have to amp both the front and the sub. I was under the impression I just needed to amp the sub alone and that a Kicker CAX 400.1 would do the trick.
The question: Do i run 2 separate amps for front/back speakers and a separate amp for the 10 inch sub or do I find a 5 channel amp that will do it all with more power to it?
Another question would be.. Do you have anyone riding in the back? I like to run something for passengers to listen too, especially on a short or even long road trip or sitting in traffic
The Kicker mono amp is 2 ohm stable and a little more expensive. The CT is 1 ohm stable and you can get more out of it by choosing a DVC2 ohm sub as I described earlier. You can look into Teramps amps also.
Aslo, if you use your head unit for phone calls, read through the manual so you can set the speakers to use with bluetooth calling to front. Trust...
6
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
180
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
543
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
531
MikedSky
CarAudio.com Newbie
MikedSky
South Lake Tahoe
audiobaun
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
Latest topics
