Kinetik or XS Power
  • 2
Looking for a new under the hood battery to replace a 3 year old Red top. Right now looking at either at another Kinetik 1800(1 in the back) or XS Power battery. Not sure about which model XS right now suggestions would help. Which brand do you guys prefer and why? I do have a problem with dimming lights on the interior and a HID kit fixed the dimming headlights. I plan on getting at least a 240 Amp alt this summer.
i would recommend against the kinetik battery under the hood. they will not warranty the battery if they find out that it was under the hood. they are not designed for under the hood applications. at least the HC series anyways. they are the best for audio batteries but within 6' of the amps that they are running. under the hood application would be best to go with the xs battery.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
566
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
744
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
567
brianh922
brianh922
Norfolk, Virgina
BoomTaco64
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
