Limit of GM Switched ignition for relays?
  • 4
yeah usually between 50-100 ohms
someone told me something about the inductive load of the light being necessary but i have my doubts. when i put a resistor in line i still only had 1.3vdc on the brown wire and the resistor was too hot to touch and started smoking (which is why i think its an internal short)
ill try calling them and seeing whats up
Resistors should work just fine instead of a light. Or, you could maybe try an L-pad and see if changing resistance matters
yeah a variable pot? almost bought one at the local electronics store
Hello, I am getting ready to install my 3000 watt taramps and 2 15s in an expedition. I am a little hung up because my old car had a 220 amp...
yeah, it'll be hot but off. Just like your tv when it's plugged in.
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio. I have a...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
878
wew lad
wew lad inc
wew lad
VA
CSCStang
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
