Line Output Converter Question
  • 4
Rwr1311
I am planning to install a single SA-12 powered by a Twisted Sounds 1.3kw. I am using the factory head unit. The factory system has a weak sub that I am replacing (car is a 2013 Audi A4 with standard audio system (not B&O)). The amp does not have speaker level inputs, so my plan is to cut the inputs to the factory sub and use a line output converter to connect to my amp.
Here are general instructions I found from someone who did a similar install: B8 A4 / S4 2010 onwards aftermarket subwoofer install | Audi-Sport.net
And here is a guy who used the line output converter solution that I described above: Aftermarket Subwoofer and Amp Install - AudiForums.com
My questions are: (1) Is this setup ok? (2) I imagine my stock system has an amplifier--does it matter if I run the LOC after that amp (by cutting the input to the factor sub)? Or will that pose sound quality issues? I would obviously prefer not to have to go through the hassle of finding the pre-amp line for the sub. (3) If I run the LOC after the factory amp, do I need an LOC that can handle a certain amount of power? Would one of these be fine:
Any input is appreciated. Thanks!
I did the exact same thing. It works great for the bass channels. But don't plan on upgrading vocal speakers this way if your car has any stock faders or crossovers. It has become a headache for me. It might just be my setup though, more experienced people may disagree with me.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
That eq only has one pair of inputs. If you want eq it may be easier to go with the LCQ-1 instead of the lc7i
Most new radios have that feature. Just check that they have 4 RCA outputs. Those are line output. If it only has 2 RCA outputs, make sure they...
Rwr1311
Rwr1311
Indiana
dubstepper1000
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
