Line Output Converter
  • 3
Just a quick question regarding installing a LOC. My LOC has 4 wires which i'm assuming are for the speakers. When installing the LOC do I just need to t-tap the wires on the LOC to the correct wires in my stereo wiring harness?
Yes, alternatively, if you have speakers close to your amp you can just t tap at the speakers.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
That eq only has one pair of inputs. If you want eq it may be easier to go with the LCQ-1 instead of the lc7i
Looking to buy and install an LOC. I got the basic functionality of it but not sure what I need. My set up is a factory Impala stock radio, 4...
Most new radios have that feature. Just check that they have 4 RCA outputs. Those are line output. If it only has 2 RCA outputs, make sure they...
samshaver18
samshaver18
Waukesha WI
pickup1
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
