Look for help with port area/length
I'm finishing up a design and starting the build in the AM but I'm having an issue designing a port people do it differently and none of the calculators are really a full help. The box is 13.32 cu ft after .30 cu ft is taken out for speaker displacement. Running 2 skar evl 15's (for now). Outer dimensions of the box are L 24in x W 48in x H 24in. Tuning to 30hz any help would be much appreciated thank you
slot port sub up port back, triple baffle with lots of wooden dowels for bracing.
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
80
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
128
Chrishxc718
South Amherst, ohio
Chrishxc718
audiobaun
    May 19, 2024
    May 19, 2024
