lost as to what to do
wenn_du_weinst
Well I have a problem
option one: spend 25k on pickup install sq system and have what I really want
option two: spend 16k on suv install same sq system with better box and buy pickup after it's paid off.
what would you do? I'm purposely not naming which cars to keep the nuthuggery at bay.
option 3...that is way too much to practically spend on audio equipment, with that said....yeah option 3
well I just figured up that I will need 15 sheets of ply wood for my uncles tower build and I have no trailer so buying a pickup makes that much easier, I do how ever have to drive my siblings around a lot and that is where the lower suv is better. both are 4 doors, 4wd, the suv gets 21mpg the pickup is 19. The pickup I will use a lot more but it's also 10k more. I can afford both very easily, both are 2007's in mint condition.
The suv has water pump and head gasket problems I've heard. (not this one but this make does)
and the Pick up has transmission problems (and no it's not dodge)
just name the vehicles...makes it easier to be bias without trying to decide on what would be easier for you to do
**** it originals won't stop resizing same thing just slightly different
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
5
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Ok. we have a way to move forward so let's get to the shopping list. I wanted to do this yesterday but I had my ass chained to an o-scope all day...
21
wenn_du_weinst
wenn_du_weinst
Bosstradamus
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
