maserati ghibli sub integration
I’m fixing to pimp out a 06 Nissan Titan quad cab short bed, thing already has a crazy torquey DOHC 32v 5.7l 385ft/lbs stock. I’m going to start with dropping it exhaust basic bolt ons and eventually throw it some boost haven’t decided if I want to go supercharger or twin turbos but it will be a beast either way. Oh and going to do up the audio of course.
Bite your tongue the GN was the pinnacle of the G-Body and **** as hell, and you always had the Typhoon and Syclone the baddest Sonoma and Jimmy ever.
I don't f4ck with superchargers anymore as they always bog down causing a bit of lag, and with larger torque the belts tear quick.
Lol the challenge was to make a 6-7+ ton vehicle a sleeper. That titan its self is fast stock.
I'm waiting to do a full rebuild with shift kit, but the 4l60e trans is sh1t and the internals on the 5.7 are good enough for now till I get the turbos which I'll need new heads.
Sent from my Moto G4 using Tapatalk
Mybad, every post here is a new argument lol.
I been on this forum for like 2 weeks and even I know that //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
There are people on here that roll with it pretty smoothly, though.
I’m from years back and had plenty of shite flinging contests it’s lost its appeal to me in my old age I’ve got white hairs in my beard since then and have too much other shite to deal with than deal with keyboard warrioring D-bags. I have respect for super chargers and in this case with it having a Thor’s hammer load of torque low in the power band (IIRC It makes 75% of its torque from 2000rpm on! Peaking at 3600rpm.) It’s one of the most responsive torque monster engines I’ve dealt with it’s a **** impressive engine. Before I go boost on it I need to turn off the ABS”limited slip” and put in a real limited sleep and might change the gearing while I’ve got the pumpkin open. It’s going to need all the traction help it can get. I’ve seen them make 500 horse and crazy torque easily at the wheels with boost.
Edit to add I believe you meant 6-7k lbs not tons and you running that Tahoe at above GRVW? Tsk Tsk the safety ninnies won’t be happy. I’ve never had lag in any supercharged vehicles including factory supercharged. I just love boost don’t care about the flavor much.
224
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
550
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
581
ajm
ajm
N/A
DaveT
