maybe a dumb ?, but have to ask...
  • 5
jailhouseracer8
BassHead
Im soon to get another treo ssx1500.1 amp. I currently have one, wired to 1 ohm, pushing my 2, 18" BL's....would i be better off running it like that? Or would it be any better/louder, if i hooked one amp per sub, and ran each at 2 ohm? Was just curious.....any input appreciated. The subs are dual 1's if that matters to anyone! thanks alot, Ed
i can handel it, but im unsure how well the treo's like .5 ohm...lol. My clectrical consists, of....big 3, with lots of extra grounds everywhere....220amp iraggi alty...2 yellowtop optimas. the amps do there rated 1500 @2ohm.
i've been running my ssx750.1 at .6 ohms daily for a few months now and it does fine. i think the 1500s can also be ran at .5 ohm daily but i don't think either puts out much more power than they do @ 1 ohm
not being familiar with your amp, 2 strapped at 4 should give you about the same output as 2 separate at 2. So, not knowing your amp, in general I would say strap em and run them at 4. IMO
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
860
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
956
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
Not sure I am reading you correctly but there is no reason to use the leads from the OEM amp if that is what you are talking about. Normally you...
jailhouseracer8
BassHead
jailhouseracer8
Odessa, Tx.
bdjacks
