Mb quart Q 4.150 3 way install help.
  • 2
Hcw
I am having difficulty understanding the instructions on installing this amp in a 3 way configuration.
First is that my Alpine head unit has only one set of rca outputs. In the three way configuration would I still have to use 2 “Y” splitters to connect to the amp? A second 2 ch amp will be attached to this amps outputs to feed a separate set of front speakers .
Second: Am I correct in assuming that it will be a 4 ohm load and require a single voice coil 4 ohm subwoofer if bridging channel 3 and 4 .( just want to confirm it isn’t a 2 0hm load)
Page 5 has a diagram.
http://www.maxxsonics.net/manuals/mbquart/pdfs/MB%20Quart%202010%20Q%20Amplifier%20Manual.pdf
I am having difficulty understanding the instructions on installing this amp in a 3 way configuration. First is that my Alpine head unit has only one set of rca outputs. In the three way configuration would I still have to use 2 “Y” splitters to connect to the amp?
The first thing you will want to do is check that your RCA outputs from your alpine are full range or can be changed to full range. If this output cannot be made full rage, time to get a new unit for this build. If yes then, you will need 2 (two) Y splitters (1F to 2M) The Q4.150 amp can support a minimum load of 2 Ohms per channel.
A second 2 ch amp will be attached to this amps outputs to feed a separate set of front speakers .Second: Am I correct in assuming that it will be a 4 ohm load and require a single voice coil 4 ohm subwoofer if bridging channel 3 and 4 .( just want to confirm it isn’t a 2 0hm load)
The number of voice coils your sub-woofer has is irrelevant, whats important is that IF bridging the Q4.150 amplifier the minimum ohm load must be 4 Ohms.
Good Luck,
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
3K
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
410
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
Hcw
Hcw
BC Canada
Dj-torn
1aespinoza
    May 19, 2024
1aespinoza
    May 19, 2024
