2 power wires from battery
  • 3
2007rustanggt
So i took one of my amps out of my car today so now i have a second 8 gauge power wire in the trunk that i want to add to the amp thats still there. If i use a distribution block from both 8gaigeare powers to a 4 gauge wire to power the sub and hook up both ground wires do i need to put a different fuse holder in there too or just buy 2it smaller fuses? Im a little confused and dont want to buy another wiring kit...
Your question is a bit unclear..
you have two runs of 8 gauge power wire from your battery to the trunk correct?
you want to know if you can somehow use those two wires into a distro block and then run 4 gauge from that to your sub amp?
If that is the case, then yes you can run 2 8 gauge wires going into one 4 gauge wire via a distribution block. Get a fused distribution block that goes from at least 1 4 guage input to at least 2 8 gauge outputs.
For example.. 1 IN 2 OUT FUSE DISTRIBUTION POWER BLOCK HOLDER 4 GAUGE 8 AWG AGU 12-V US SELLER | eBay
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
222
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
576
2007rustanggt
2007rustanggt
Fort worth, tx
Dj-torn
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
