I am having difficulty understanding the instructions on installing this amp in a 3 way configuration.
First is that my Alpine head unit has only one set of rca outputs. In the three way configuration would I still have to use 2 “Y” splitters to connect to the amp? A second 2 ch amp will be attached to this amps outputs to feed a separate set of front speakers .
Second: Am I correct in assuming that it will be a 4 ohm load and require a single voice coil 4 ohm subwoofer if bridging channel 3 and 4 .( just want to confirm it isn’t a 2 0hm load)
Page 5 has a diagram.
http://www.maxxsonics.net/manuals/mbquart/pdfs/MB%20Quart%202010%20Q%20Amplifier%20Manual.pdf
