measuring amp output without clamping it?
  • 2
detroitdiesel
alberta
I was wondering if i would find the max output of my amp without clamping it? I would do this by measuring the AC voltage on the speaker terminals of the amp along with this formula..... voltage = sqrt( watts X ohms). By Using a 60hz tone -6db, couldn't i find my voltage at max gain, with bass boost turned all the way down, then fill in the ohms, with the resistance of the subs, and then solve for watts?
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
941
183
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
384
6
483
detroitdiesel
detroitdiesel
alberta
pheonix991
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
