mini cooper, wall, 2 18" mts, 6kw
crazy
lots of work definately going into this project..
just think as others have said it would of been a lot easier and cleaner if a boxed wall had been made instead of all the steps and what not.
either way looking forward to seeing the end results
would have been easier, but as said before, even as the box is now, im already running on the low side with airspace...that little extra bit i gained by doing the sides how i did, will help that much more..
idk if that was said....but wouldn't it have been easier to build a square box and just seal off the rest?....or is that not the way to make a wall //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Read 3 posts before yours.
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
orangecounty1
orangecounty1
Tampa, FL
RAM_Designs
