Mini dsp 2x4 vs 6x8 anyone
  • 3
heyhi1
nyc
With a front 2 way setup only what is the difference beside 200 bucks? Does it have the same options but more channels or will the 6x8 give a noticeable better sound quality?
Do I need to go active with a dsp or can I stay passive and increase the sound quality?
afaik they retain the same sound quality one just has more room for more channels. if you have the money and plan on expanding in the future id go with the 6x8 for sure. you can get a ppi dsp-88r or soundstream harmony which is 2x8 for significantly less but they sacrifice component quality for cost. im happy with my dsp 88r if that matters
Still need to make sure I can stay passive and improve quality. I'm about to order the 2x4 if I can
you can improve sound quality with time alignment and eq'ing, if you take the time to do it
going to need an accurate calibrated rta mic if you decide to eq (unless your ears are good enough to hear peaks/troughs that need to be boosted/cut)
I recommend getting the c-dsp instead so you have control over your subwoofer as well as well as room for a midrange in the future. You can easily go from passive to active with a 4 channel amp and get far more tuning control than you realize at this time.
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
4
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
heyhi1
heyhi1
nyc
The Camry
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
