Most likely causes of 'pop' when changing track or source on head unit
  • 2
Atlanta007
Atlanta
Hello, I'm running a fairly basic system in an older Mercedes. An Alpine CDA-9805 head unit, a Clarion compact 4 channel amp and a set of 4" coax Helix speakers in the front and pair of 5 1/4" Alpines in the rear deck. I didn't want to cut or alter this car to provide for components, and I'm not running a subwoofer. The system sounds pretty good, but I get a very audible and annoying 'pop' from all 4 speakers most of the time I change tracks on the cd or ipod, or switch source from cd to aux (ipod) to radio. I don't get any alternator whine and I've rechecked and improved the grounds for the HU and the amp, but no change in the pop.
Is this typically a wiring issue, maybe the RCAs too close to power or speaker wires, or does it sound like a problem with the HU? I'm using decent quality rcas and quality 16 gauge speaker wire. Thanks for any input.
Make sure the fluttering sound you are hearing isn’t something flexing. When I start pushing my subs, the sunroof sliding cover flexes so much I...
29
5K
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
4
988
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
968
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to...
Atlanta007
Atlanta007
Atlanta
1aespinoza
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
