New DAB stereo wiring problem blown fuse.
  • 2
citc4
CarAudio.com Newbie
Hi all,
I have just tried to install a DAB radio Grundig GX-42DAB BT USB AUX RDS DAB+ in a Citroen C4 l 1.6 2005
I have used an adapter from original socket to DIN1
I tried to connect the yellow wire to the red to get 12V, the result was that the 20A fuse blew in the dashboard fusebox.
The radio won´t light up.
Now im stucked, should i run 12V+ fused 15A directly from the batteri to the radio, through the yellow wire in the connector?
Or what could be my best option?
Help is much appreciated!
All the best!
35821
Hi. I've ordered a pioneer deh s720dab stereo for my renault master van. I'm aware that an adapter can be used to use the existing roof top fm...
Link to antenna. I'm guessing the copper foil should be connected to glass, not metal, but lets see the antenna. Did it come with instructions?
I know this must be a simple fix! But can't work it out! When the head unit is out of the cage/holder the radio and DAB reception is perfect. As...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
219
citc4
CarAudio.com Newbie
citc4
Denmark
citc4
