did you even look at the motor or the motor mounts? if a motor mount is bad you can usually visually tell by the way the motor sits (it'll lean). I can tell you if the motor mounts are bad but I'd have to actually see the car in person. this is like calling your mechanic and saying "my car doesn't work fix it". if a motor mount is bad it can cause vibration at high speeds as well as at idle, depends on the severity of how compromised the motor mount is. vibration shouldn't be that bad at high speeds b/c the motor doesn't move as much and usually at higher speeds you have a constant load on the engine. if the car has a cable pull throttle body you can just start the car up, pop open the hood and give a little throttle and see how much the engine moves. the movement should be minimal, if it move alot than chances are a motor mount is bad. also it will depend on the location of the motor mounts as to what the car will do. it may also be a transmission mount. either way a motor mount is a relatively simple swap if you have the right tools. some can be swapped with only have the engine supported on a hoist, other are pretty much the same just might have to remove one or two more brackets.
