Mounting a subwoofer to a custom box
  • 1
Heresy
Going Against the Grain
1,216
Arizona
I am new to the speaker box building community and have no idea what kind of screws to mount the subwoofer with. The box is already built and all I have to do is drill and mount the subs. I know t-nuts should be used but should I use metal or plastic screws? Should I use additional gaskets is the sub already has its own? It seems stupid, but can someone please help.
I have always used 5/8 - 3/4 inch metal screws and drilled directly into the box. The supplied gasket should be good enough. The only prob that I have encountered with my may of sub installation is that if you need to remove the sub from the box a couple of times, the cheap pressed fiber board tends to start falling apart around the screw holes. When this happened to me I just repaired the box with a plastic wood filler. You can re-drill the holes once this stuff dries.
I’ve installed a lot of brand new subs before. Like we’d build boxes and install the new sub into the box, and then install the box and tune the...
23
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
Heresy
Heresy
Arizona
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
