MTS to MPG Converter for MAC, Convert MTS to MPG on MAC OS X
andyniki
China
Record video in AVCHD formats with Sony NXCAM, but the default media players from Apple (like QuickTime) will not play AVCHD natively? With MAC MTS to MPG converter, you can convert MTS video to MPG which can be accepted by QuickTime/iPod/iPhone/iMovie etc. freely on MAC OS X.
MAC MTS to MPG converter convert MTS/M2TS/TS Video to MPEG-1 for MAC.
MPEG standars, including MPEG-1, MPEG-2 and MPEG-4, is often used for video and audio compression and transmission online, in television broadcasts, and in DVD media.
With MTS to MPG converter for MAC, you can convert/import MTS to MPEG-1 which mainly used on video VCD,SVCD. Of course, you can rip audio from MTS video and saved the output format as MPEG-1 Layer 3 Audio (.mp3) which can be player with QuickTime/Itunes.
MAC MTS to MPG converter convert MTS/M2TS/TS Video to MPEG-2 for MAC.
With MTS to MPG converter for MAC, MTS to MPEG-2 for iMovie`08 for further edit, MTS to MPEG-2 to burn it onto a DVD-R and play with DVD player.
Problem about import MPEG-2 video to iDVD for MAC:
I have an MPEG-2 file I'm unable to import it into iDVD. I convert an MPEG-2 file to a quicktime movie format using Quicktime 7 Pro, but iDVD lost the audio, any help?
Suggest:
unless you demux the MPEG-2 and create the QT movie as separate tracks can above method work. In fact, just with MTS to MPG converter for MAC, you can get MPEG Stream Clip or Toast to export the MPEG-2 to DV/VOB Stream and use that as your input to iDVD with least quality loss (only one "lossy" compression involved rather than two).
TIPS:
MPEG-1 and MPEG-2 can be played by VLC media player and Mplayer freely.
MPEG-1, MPEG-2Video file formats and associated codecs (such as AVC) can be accepted by QuickTime.
iMovie '08 works with many tapeless camcorders (record flash memory, a hard disk drive or DVD mediausing) can use MPEG-2 and AVCHD formats. But if you use the AVCHD format you will need a Mac with an Intel-based Core Duo processor or better. And you also can convert mpeg-1 to mpeg-2 with MTS to MPG converter for MAC.
MTS to MPG converter for MAC convert/import MTS/M2TS/TS Video to MPEG-4 iPod/iPhone/iMovie/Apple TV/PSP etc on MAC OS X
With MTS to MPG converter for MAC, we can freely convert MTS to MPEG-4, M2TS to MPEG-4, TS to MPEG-4, then import MTS to iPod, MTS to iPhone, MTS to iMovie, MTS to Apple TV, MTS to PSP, MTS to Creative Zen with suitable resolution. Surely, you can extract audio and saved as MPEG-4 AAC Audio (.m4a,.m4b, .m4p) that can be played with QuickTime.
Tips:
With MTS to MPG converter for MAC, you also can convert AVI to MPEG-4/1/2, MOV to MPEG-4/1/2, MKV to MPEG-4/1/2, WMV to MPEG-4/1/2, VOB to MPEG-4/1/2, FLV to MPEG-4/1/2, ASF to MPEG-4/1/2 etc and also MPEG-1/MPEG-2 to MPEG-4 vice versa.
MAC MTS to MPG converter Transfer MTS/M2TS/TS Video to other popular formats(AVI/MOV/WMV etc.) on snow leopard
With MTS to MPG converter for MAC, you can transfer MTS/M2TS/TS toAVI/WMV/MKV/FLV/MOV/VOB/3GP/HD video etc, rip audio from MTS files and set the output format as AAC/ AC3/ AMR/ M4A/ MKA/ MP3/MP2 etc, import MTS video to various portable players like iDVD/Blackberry/GPhone/itunes/Creative Zen/iRiver/Zune etc on snow leopard MAC.
Edit MTS video to MPG/MPEG Format with MAC MTS to MPG converter on MAC OS X
With MTS to MPG converter for MAC, you can adjusting the brightness, contrast and saturation through Effect, adjust Resolution, Bit Rate, Frame Rate and Encoder of video and Bit Rate, Sample Rate, Channels and Encoder of audio through Setting, set starting time and ending time of MTS video through Trim, remove unwanted black edge of your video by set aspect ratio of MTS video through Crop.
it can give you something ,maybe ,you will,like it ,you can click the link ,and follow the guide,have a try,
it can be free download!
Do you know what .MTS is? The .MTS file format is extension of AVCHD video format which is based on the popular MPEG-4 video codec and is a high definition MPEG, AVC, H.264 transport stream video file format. Do you want to own a powerful MTS Converter and then use it to help you to convert mts file to avi,convert mts file to mpg, convert mts file to mp4, convert mts file to 3gp, convert mts to vob, convert mts to mov. To do this conversion, I also can share with you MTS to AVI Converter and MTS to MPG Converter or MTS to MPEG Converter
Tanbee AVCHD Converter for Mac converts AVCHD(MTS/MT2S/MOD/TOD) videos to all popular HD/Common videos suitable for different mobile devices.
AVCHD Converter for Mac can be used like MTS Converter, M2TS Converter, TS Converter, MOD Converter, TOD Converter, etc.
This step-by-step guide will show you how to convert video files with this software.
Before you start, please download, install and launch
AVCHD Converter for Mac.
Step 1: Load video files
Click "Add Files" button to add video files you want. After video files are imported successfully, you will see all of them listed in the program:
Step 2: Select output format
Select one or more files in the file list, click "Profile" drop-down button, and select an output format for the selected files in the drop-down list that opens.
Step 3: Edit Video (Trim,Crop,Effect)
Select a video file in the file list, click "Trim","Crop","Effect" button to open window for edit.
Step 4: Convert
After the above settings, check the needed files to convert in the file list, and click "Convert" button on the window to start converting.
http://www.avchd.converter-for-mac.com
Note: This version is for Mac OS. If you are using Windows, please click here.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
  • Locked
Cerwin Vega IOEM8 8ch line converter for sale, bought brand new as A-stock last summer. Mounted to baffle in preparation for installation but...
Update. Took line out back and just upgraded my head unit. Now my sound only plays when fade is in rear and balance to left. Ugh. One thing after...
20
3K
andyniki
andyniki
China
cynthiachen
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
