Southeast Region My First Comp (And Win)
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
MemphisSoul4U
The Black 'Hoe
Just went to and won my first competition at Toys for Tots show in Maryville.
The only thing I was upset about was no one was in my class...
But I did beat myself.
My first run was a 136.1 with my sub at 2 ohm. Rewired it to .5 ohm before the reruns and hit a 138.2. Would've had it wired to .5 ohm already but my amp isn't supposed to handle it (only rated at 2 ohm). I've had it at .9 ohm for daily driving and it worked fine. Plus if it fried, I already need to upgrade amps anyway. Wanting a MA Audio HK4000D...
The one thing I'm extremely proud of is hitting a 135 at 26 Hz with one 10. My friends that I went with were running 12s and 15s that couldn't even play that low...
Can't wait til the next comp! Hopefully by then I'll have a HK4000D and be putting up bigger numbers... I'm hooked!
You did 135 @ 26Hz? What do you have the box tuned to //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Good lord, that's a lot of output...
Also, I bet your actual impedance as seen by the amp is nowhere near what you think it is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm frankly amazed you didn't blow the driver to smithereens //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
135dB is a ton of output below tuning...
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
466
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
I know that feeling. I just changed headunits, so along with a DSP I have a 21 band parametric EQ on the HU. Since I have to plug my computer in...
18
MemphisSoul4U
The Black 'Hoe
MemphisSoul4U
Calhoun,TN
MemphisSoul4U
    May 20, 2024
    May 20, 2024
