Southeast Region My First Comp (And Win)
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
  • 3
MemphisSoul4U
The Black 'Hoe
Just went to and won my first competition at Toys for Tots show in Maryville.
The only thing I was upset about was no one was in my class...
But I did beat myself.
My first run was a 136.1 with my sub at 2 ohm. Rewired it to .5 ohm before the reruns and hit a 138.2. Would've had it wired to .5 ohm already but my amp isn't supposed to handle it (only rated at 2 ohm). I've had it at .9 ohm for daily driving and it worked fine. Plus if it fried, I already need to upgrade amps anyway. Wanting a MA Audio HK4000D...
The one thing I'm extremely proud of is hitting a 135 at 26 Hz with one 10. My friends that I went with were running 12s and 15s that couldn't even play that low...
Can't wait til the next comp! Hopefully by then I'll have a HK4000D and be putting up bigger numbers... I'm hooked!
You did 135 @ 26Hz? What do you have the box tuned to //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Good lord, that's a lot of output...
Also, I bet your actual impedance as seen by the amp is nowhere near what you think it is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm frankly amazed you didn't blow the driver to smithereens //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
135dB is a ton of output below tuning...
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
I know that feeling. I just changed headunits, so along with a DSP I have a 21 band parametric EQ on the HU. Since I have to plug my computer in...
18
MemphisSoul4U
The Black 'Hoe
MemphisSoul4U
Calhoun,TN
MemphisSoul4U
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
