My last decision...for awile...hopefully šŸ˜‚
  • 1
spokey9
5 time International Booty Bandit Gold Meldalist
5,010
1,876
NE AR
So I'm split what I should do...I can buy a 2 channel to run my tweets for a 2 way active up front or I can buy a pair of 3-4" mids (off parts express more than likely) and use the axerra 4 channel I got to go 3 way active upfront
Right now I got a power t400.4 to run the 6.5 cdt in the front doors and the 6.5 cdt coaxes in the rear doors
I'd have to run my subs off the sub out on the hu to go 3 way...there's a fair bit of adjustments on the hu though...the mids and highs would be through a dayton dsp-408...I plan on using the dsp primarily as an eq...
Would I be better of staying 2 way upfront or going 3 way with what I got so far? Either way I've gotta buy a 2 channel or a set of mids...this fall I'll be adding a front sub as well
Cdt HD-6SEX.2
Cdt HD-65S
Cdt DRT-20
Pair of sql-15
Rf power t400-4
Taramps smart3k
And if I go 3 way
axxera ax460d
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
6
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
995
spokey9
spokey9
NE AR
spokey9
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
