Mystery subwoofer ....
  • 4
I have an 18" FI Audio Btl with what looks like a DC audio recone which is supposed to be dual 2 ohm but Everytime I check the impedance I am getting 2.8 per coil and 1.6 in parallel... DC doesn't make dual 3 ohm and neither does FI. So how is it that I have a FI motor, DC dustcap, and maybe a JL recone maybe? Lol.. anybody have any ideas? Or are these readings possible for a dvc2 ohm??
I am getting a .4 reading from my dmm but still I feel like that's odd because I've checked other speakers and gotten usually lower the resistance of the sub... Like a raging of 1.8 or 1.9 for a 2 ohm sub not 2.8
I use D2.7 coils. It is probably not an OEM coil but that's not terribly unusual DCR. 4 subs coils parallel make .7 ohm which gets you a bit more power than 1 ohm and is a bit easier on amps than .5
Run that into a 2 ohm stable amp or two 1 ohm stable amps strapped and it's a good match. That is NOT a great impedance for running single sub for most applications though.
OK, I kept on searching for the answer - found it! I was able to find an exact wiring diagram for my XVM279BT APPARENTLY the blue wire acts as...
Well, the odd thing is, page 3 of that manual shows the left socket as the rear view input, mute, and steering wheel control. While the right side...
You probably did it already, but post this to 350z specific forums or facebook groups, etc. There's probably someone there that knows.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
Lmobeats
Lmobeats
North Carolina
hispls
audiobaun
    May 19, 2024
    May 19, 2024
