Need a 900.4 cheap and used
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
150
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
111
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
456
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
351
lovinloudbass
lovinloudbass
WI
Austin175
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
