need advice on a good equalizer
  • 3
boomboom23
Wi
I am running 3 10inch alpines with hertz space 6 in the rear and jl c5 components in the front.memphis amps to power everything and alpine cda9884 deck I want to add a nice equalizer to improve my spl. Should I get one I can mount in my dash and adjust on the fly or get like the kicker 30 band eq?
here's the kicker: WoofersEtc.com - 03KQ30 - Kicker 30 Band Equalizer
Or something like this:
WoofersEtc.com - 03KQ5 - Kicker 5 Band Equalizer
I don't need to get kicker I just wanted to show you guys the difference in what I am looking at, one is set then never touched and the other can be messed with on the fly..i also kinda like the digital ones they seem nicer??
I also like this one" http://www.woofersetc.com/p-5100-16-eq30-memphis-30-band-13-octave-equalizer.aspx
Throw out some good ideas guys price im looking at between 200 and 350..i want a nice one
Audio Control has some of the better trunk mount EQ's. Just watch what model your choose as you can lose fader and sub level control when you have only one input on the EQ.
I prefer control in the dash, more than a 1/2 din can offer. A PXA-H701 or similar would give more tuning options from the drivers seat. Separate EQ, crossover, T/A, phase for each driver. Helps achieve maximum clarity and volume. And it is comparable with your HU.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
370
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
489
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
830
boomboom23
boomboom23
Wi
keep_hope_alive
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
