Need advice on electrical system don't want to strain
  • 4
So I have a 98 rodeo and it only has a 90 amp alt In it I am going to upgrade the power and ground leads this weekend but will this allow enough current flow to hook up a second amp I currently have a Rockford fosgate r750-1d pulling around 60 amps and I just want a small like 50-75 watt alarms amp for my front and rear door speakers will this be alright or do I need to get a ho alt I don't dOnt really have money for one right now so it would put things on hold but don't want to cause electrical problems for a second amp
start with the Big 3, then use a volt meter to monitor the voltage as you drive. keep an eye on it. if the car can't maintain 13V on a regular basis, then you need to address the charging system.
no one can predict how you will use your system. music is dynamic and draw is usually minimal except for impact and bass drops.
Thanks and when u say use a volt meter do u mean like the kind that you hook up and has a digital read out in the car or what I have seen them but don't really know much about them
I read a thread on the voltage meter and wasn't sure for what I'm trying to figure out if the electic system is being over taxed would I want to hook up the voltage meter to the battery or my amp
yes. there roughly 20 bucks off of amazon. basically you run 2 wires. one to the the positive of the battery, one to the negative. then you run a remote wire to the ignition wire. so that when the ignition is on, the meter pops on
504
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
610
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
893
Quinn88
Quinn88
Eugene, Oregon
robert420
