Need advice on recent install for 2012 F150
  • 3
Drew Barry
CarAudio.com Newbie
I recently installed 2 6x9 Alpine SPR-69 speakers in my 2012 F-150. I added an Alpine MRV-F300 amp to power all speakers. The headunit is a Kenwood DDX9703S.
It sounds ok but something seems off with the distortion and can't get the clear bass I'm after. I'm wondering if having 2 way speakers in the front doors now with the factory tweeters still hooked up is causing issues with Ford's factory crossover? I've messed around with every setting on the amp and headunit and just can't seem to get it right.
I was thinking about moving the SPR 2 way speakers to the rear doors and just installing component speakers up front.
Any advice would be greatly appreciated!
We need more information about the signal in and amplification out to really help.
Factory amplifier?
How did you wire the headunit the 4 channel amp?
How did you wire the 4 channel amp to the speakers?
Do your 6x9s have a factory crossover?
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
371
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
492
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
832
Drew Barry
CarAudio.com Newbie
Drew Barry
wew lad
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
