Need Advice On Some Old School Eclipse Subs...
  • 4
SoCaL081
50
I recently got some old school 12" eclipse sw8122dvc aluminum subs and was wondering if this box (link below) would work and sound ok. I cant find a manual or any info on them really. Ive came across some saying that these subs are really underrated and handle way more than 500w rms? What would a good amp and size for them?
GROUND SHAKER (#GS-SQP212B) 12" DUAL PORTED SUB BOX
SPECIFICATIONS:
-CUTOUT DIAMETER: 11 1/8"
-TOTAL AIR VOLUME: 2.60 CUBIC FT.
-2 INDIVIDUAL CHAMBERS
-VOLUME PER SUBWOOFER: 1.30 CUBIC FT.
-TUNING FREQUENCY: 35-Hz
-1 SLOT PORT FOR EACH SUB (DIMENSIONS: H-11 3/4” W-1 1/2” L-27”)
-WEIGHT: 54 LBS.
-MOUNTING DEPTH: 14"
DIMENSIONS:
-HEIGHT: 13 1/2”
-LENGTH: 33"
-DEPTH: 17 1/2"
CONSTRUCTION:
-3/4” HIGH DENSITY MDF WOOD
-CARPETED WITH DURABLE TRUNK LINER FINISH
-SEALED WITH HIGH QUALITY SILICONE
-2-SPRING LOADED TERMINALS
I found this in a SuperHonda forum from 2004 asking about the enclosure specs for the SW8122DVC...
"since no one knew, i called Eclipse and asked them.
So for searching functions for future questions on this:
Sealed can be anywhere from 1.65-1.9 ft3
Optimal overall enclosure for these subs are 1.65ft3 per sub sealed and that will give an great overall freq response
Optimal ported should be 2.5ft3 per sub with (1) 5 inch diameter x 14.25 inch long port per sub."
Hope this helps.
Would this be good? Or the one in the picture if I just cutout it for a 12 instead of a 15?
357
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
472
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
822
SoCaL081
SoCaL081
Simple simon
    May 18, 2024
    May 16, 2024
