need advice on speaker choice
  • 2
Polks are a much better speaker of the two.I still run mt DB.6.5s from time to time, and they sound really crisp and clean on clean power. Ive ran Kickers in the past in which were great but seem to lack some clarity that Polk generates,as well as durability.Loud screaming/muddy if you like? go with Kicker..SQ with some clarity and durability as well as take some clean power? polk in this case..The only Kickers since the older KS series Im Die Hard on are the KS-25 tweeters.Some of the most durable loud azzed tweeters I still own and run today.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
480
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
591
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
881
gilbertj77080
gilbertj77080
houston
audiobaun
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
