Need an install I'm from philadelphia
Awesome bro. How good are you with 3sixty.2? It'll probably be the hardest part of the install. I just need comp set/amp, sub/amp and the processor installed
No, nothing is done. I won't even have all the items until the end of this week. I ordered a 1508 with enclosure direct from DD gonna push it with JBL GTO601.1II. I also ordered dls up6i's and CADENCE IA4 to push them. And of couse the 3sixty.2. I just will use factory for rear fill direct to HU I'm a big front stage only fan
Many whom bypass the OEM amp, tap into the harnesses there. It is all there in one spot so no need to remove panels or runners. Just Google 2017...
This thread is over a month old. Shame I missed it, the whole thing is shameful and hopefully OP made those people give him an install that...
Ok. If you buy tweets they’ll come w their own inline crossovers. Youd connect the speaker wire to the crossover which then connects to the...
851
172
203
Ampz
Ampz
Philly
Ampz
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
